Dell G2724D thoughts and feedback
Viewing 9 posts - 61 through 69 (of 69 total)
  • #75339
    todorson
      You know that you can increase max brightness and sub brightness in the service menu?
      By default, max brightness is set to parameter 201 (it can go up to 255), some users after increasing max brightness to 255 were able to see difference in contrast, etc…
      I am not sure, I can see some differences, but also it could be placebo effect.
      To enter service menu:
      – turn off monitor, keep pressed button 1 and 3 (in order, under menu stick first button is 1), turn it on, release both buttons when screen is on and then press button 4.
      You will see a small blue screen on the top left side of your monitor, you use menu dialer to go through options.
      Keep us posted if you see any changes, anyone.
      Cheers.
      #75348
        Interesting, thanks for sharing that.
        #75379
        jxeedon
          Hello. Does anyone know what the best sharpness setting for this monitor is? I know that no added sharpness can be 50 on some monitors.
          #75807
          Frosty
            Just a little update on the dell g2724d.
            The rtings review and most of reddit reviews that had good reviews for the monitor (and were kind enough to respond to my question) are from the rev A00 model.
            I tried 5 different Dell g2724d A01 rev panels, the backlight bleed was way too much. I had confirmed 2 DOA with the service centar, and eyeballed the rest (found a dead pixel on one of them).
            So be advised, seems like they either had a factory defect with the A01 or they changed panels.
            #75809
              Thanks for confirming, it’s a shame the monitor seems to have been revised into a worse state. 🙁
              #75861
              todorson
                This silicon, panel lottery, etc.. are becoming so annoying lately, it seems no matter the money, you also need some luck. Sigh.
                #75883
                MarzoK
                  Do you (or anyone else) know, which panel is used in the newer revision?
                  #75972
                  maverick111x
                    I opened mine that was manufactured in March 2024. It is rev A01 and still has the same panel, M270DAN08.C
                    #75976
                    MarzoK
                      Thanks. Finally a very useful information…….it´s still the only monitor which is using this panel i think.
