- October 4, 2016 at 11:45 am #40170
karandex
OK then S2415H it is. Need to save bit for it. Samsung was 30 usd cheaper with free bluetooth levelu headset.
October 4, 2016 at 9:02 pm #40176karandex
So what i am getting is va have better contrast and ips hav better e viewing angle and Colors . I am still torn Between s2415h and cf390. The later ia about 50.usd cheaper.
October 4, 2016 at 9:10 pm #40177PCM2
It’s highly subjective and above the detailed analysis I’ve given already in reviews and on this thread I can’t really provide further assistance. It’s a decision you’ll have to make yourself.
October 5, 2016 at 8:17 am #40178karandex
I checked out hardforum regarding dell and all of the people there had issue with ips glow. How big is this issue?
October 5, 2016 at 8:27 am #40179PCM2
The effects of this are covered in the review. The level of IPS glow on that model is in my view quite typical for an IPS-type panel of the size. A little more than some of the models with relatively low glow, such as some of the glossy 25″ HP models, but not a dramatic difference if the brightness of both is at a sensible level (i.e. lower than it is out of the box). It’s highly subjective whether it would be a problem for you or not I’m afraid, it’s just another thing you really have to judge for yourself first hand.
May 6, 2017 at 6:22 pm #42856svardie
Hi. Just bought Samsung C27F591FD monitor, thanks to review. Overall impressions quite good. This is my first 27″ curved monitor. Now first “wow” effect has past away. So, i spending my time messing around with settings, trying to make it better than default settings. It will be good to see other people’s settings here. I don’t have special monitor calibration equipment and software, so only things that i can rely on is my eyes and other owners experience.
Right now i’m using settings from Adam’s reviews:
58 brightness
75 contrast
60 sharpness
Custom color settings: R50 G45 B43
Gamma mode 1
Upscale Off
Game mode Off
Response Time FasterI don’t understand, why use Response Time on “Faster”, rather then “Fastest”. Isn’t it good to make response as fast as possible, or it will come with some negative effects, when set to “Fastest”?
P.S. “Game mode” is so bad, i don’t even understand why someone would use it. My eyes bleeding from it.
May 6, 2017 at 6:25 pm #42860PCM2
Yes, ‘Game Mode’ is terrible. It is on many monitors but I make specific effort to urge people in the review not to bother with it. The reason that ‘Faster’ is used rather than ‘Fastest’ is covered in the written review for the C27F591. ‘Fastest’ introduces significant unsightly inverse ghosting (overshoot) whilst conferring no real advantage. Avoid it, along with ‘Game Mode’.
May 11, 2017 at 1:51 pm #43110svardie
I found http://www.lagom.nl website, made some tests and find this settings suitable for me:
Brightness: 58+. I add more, when playing games.
Contrast: 75.
Sharpness: Upscale to Mode1, when playing games. 60 when not.
Color: Standart (50/50/50). Reason why i changed it from 50/45/43 is that i can barelly see last square in “White saturation” test when using default settings and can’t see it at all when using 50/45/43.
Gamma: Mode 1
Response Time: FasterJuly 1, 2017 at 4:18 pm #43735svardie
Is there is any info about how upscale technology works in Samsung monitors? Does it provide any extra latency to image processing? I cant decide rather i want to use it or no. I run my monitor in native 1080p so, probably, no. But its add some nice extra sharpening in games, where native image is blurry and unclean by itself. Mode 1 seems to be not so unnatural, but i turn it off when not gaming mostly.
July 1, 2017 at 4:25 pm #43736PCM2
It simply oversharpens the image. It is no different to a specially tuned sharpness control and has no processing delay impact (i.e. does not add latency). It is called “MagicUpscale” because it is designed to compensate for some of the softening associated with viewing low resolution content or running the monitor at a non- native resolution. If you like the look it gives by all means use it. It will not impact responsiveness.
July 1, 2017 at 4:52 pm #43738svardie
Thank you for answer.
After few months wth C27591FD i personally like “Basic color” mode mostly. I like how it gently lowers image saturation little bit, so image feels more natural for me. Great monitor after all, very satisfied with him.September 24, 2017 at 1:21 pm #44843sludgebelcher
Looking for a 1080p, ~24″ multimedia monitor for movies, casual gaming, and general desktop use. My primary monitor is Acer XB241H (FHD, TN, 144Hz) and I think the colors look fine, maybe a little washed. I’ve never experienced VA or IPS monitors so I’m not sure which panel type is best but from what I read it’s either IPS or VA so I’ve narrowed my options to:
1- IPS: Acer CB241HY or Samsung S24E310HL
2- VA: Samsung C24F390 vs Samsung C24FG70 (a little too expensive)September 24, 2017 at 1:25 pm #44848PCM2
Hi sludgebelcher,
I’ve merged your thread with this one as it’s an appropriate place. I’d advise taking a look through this thread, or at least my first post and watching the video there. That should help you choose either the VA or IPS path.
As for the models you mention, I assume you mean Samsung S24E390HL, because the S24E310HL is a VA model?
September 24, 2017 at 4:04 pm #44849sludgebelcher
After watching your video and reading your first post I decided to choose a VA monitor. Question: In your opinion, Is C24FG70 worth $100 more than C24F390?
Thanks AdamSeptember 24, 2017 at 4:22 pm #44850PCM2
It depends if you were planning to replace your XB241H completely or use both models for different tasks. The 144Hz refresh rate would certainly make the CFG70 easier to adjust to if it is going to be a replacement. But if you were only really going to use it as a secondary screen with less of a focus on gaming, the C24F390 should be fine.
January 4, 2018 at 8:05 am #46378d3Zz
Hi there!
First of all, I want to thank for all the amount of information in this website, I have been reading a lot and I finally decided to post here.
I am looking for a 24inch monitor for my MSI GE62 2QF Apache Pro (GTX 970m). I recently bought the Iiyama ProLite XU2492HSU-B1 but I was so disappointed on the black color levels (they all look poor and grey…) that I decided to give it back.
After reading and searching I found the following VA models.
– Samsung C24F390FHU
– MSI Optix G24C
– Samsung C24FG70Good for gaming and reproducing the black color levels as well as having a good overall quality. They all have the same technology but I can’t decide. I don’t need more than 60Hz and FreeSync, therefore, the C24F390FHU would be ideal. But I really want colors, black levels, and image quality to be as good as possible. In most of the reviews, the C24FG70 excels on color/image quality but is the most expensive of course. Do you think the C24F390FHU will be enough? Can you think of any other recommendations?
Thanks 🙂
January 4, 2018 at 8:09 am #46380PCM2
Hi d3Zz,
One of the key advantages of the C24FG70 compared to the other models is its generous colour gamut. Whereas the C24F390FH (and MSI) just scrape past sRGB, the CFG70 provides a good boost beyond that. This enhances colour vibrancy quite considerably and helps counteract some of the weakening saturation towards the bottom and flanks of the screen.
Having said that, the C24F390FH still provides strong contrast and reasonably vivid colour reproduction and should provide a better experience (in theory) than the Iiyama you discarded. As you have no use for higher refresh rates, I do feel it might be misplaced to spend more on the CFG70. But make sure you can get the CF390 from somewhere with a good returns policy just in case.
January 5, 2018 at 2:54 am #46400d3Zz
Thanks for the answer,
I finally bought the C24FG70, I really like image quality. Once I update my PC in the future then I will be able to use the FreeSync and the higher Hz rates.
Little investment. I hope I like it as much as you do 😀Best,
June 14, 2018 at 3:28 pm #47482PCM2
Note that the BenQ EW277HDR has replaced the Samsung C27F591FD on our recommendations page, as an excellent 60 – ~75Hz Full HD VA model. I like the curve of the Samsung (but can live without it), it has FreeSync and has slightly better pixel responsiveness. But the BenQ has; a wider colour gamut (more vibrant), better static contrast, less ‘VA glow’, no weird subpixel structure (better text clarity), is free from ‘interlace pattern artifacts’, less overshoot and uses a lighter screen surface. It was a simple choice for me to feature it as a recommendation really. and that has been strongly reinforced by user feedback I’ve received from those I’ve recommended it to. It’s not perfect, but it is worth every penny of its asking price in my view.
June 15, 2018 at 5:30 am #47485MASKOAA
Good to know PCM, do you happen to know if theres a difference between that BenQ and the non HDR version under the same name? Obviously HDR is missing but would be cool to know if its the same panel. I’m currently using the Samsung C27F591 based off your review and couldn’t be happier but I’m always glad to hear of a replacement in case something happens to it. One thing I recommend for everyone is bias lighting if your setup supports it….a white light casted on a light colored wall preferably a white wall or a light light grey will noticeably increase the inkyness of the black levels especially on VA panels.
