Which panel is used in Dell P2723D? True 8-bit panel or 6-bit panel with FRC?
Viewing 4 posts - 1 through 4 (of 4 total)
  • #76427
    sk
      Which panel is used in Dell P2723D? True 8-bit panel or 6-bit panel with FRC (dithering)?
      Or probably someone know which panel is used in Dell P2723DE? I suppose that the panels used in Dell P2723D and Dell P2723DE are the same.
      #76429
        They will use the same panel, but I’m not sure which panel that is and whether FRC is used. I’ll leave this thread open in case anybody does know the answer to this.
        #76742
        sk
          If the displayspecifications.com website does not clearly state whether the P2723D monitor uses FRC or not, does that mean that FRC is most likely used?
          #76744
            No, it means they aren’t aware of the panel used and it hasn’t clearly been specified by the manufacturer or another reliable source.
