sRGB clamp on Linux – possible?
Viewing 8 posts - 1 through 8 (of 8 total)
  • #76960
    radosuaf
      Due to soon demise of Windows 10 and my hatred towards Windows 11 I’m trying to switch to Linux. What sets me off however is the fact that my monitor is a wide gamut one and the reds just burn my eyes. I’ve been trying to find anything on sRGB clamp for Linux, but is seems that there are no solutions apart from full calibration…
      Anybody managed to do this by software? I’m using an AMD Radeon card.
      #76962
        It should be possible, but is less straightforward than with Windows.
        #76963
        radosuaf
          This one is NVIDIA specific, unfortunately…
          #76965
            Ah yes, good point. Given that the only option I’m aware of on Windows on the AMD GPU side is the AMD driver clamp (or Windows ACM), I doubt it’s possible on Linux unfortunately.
            #76966
            radosuaf
              Hmmm… I’m using Ubuntu but decided to give Fedora KDE a try, I applied the ICC profile and it seems sRGB clamp was automatically applied! It didn’t happen even in Windows. Is it possible that ICC profile automatically assigns sRGB colour space?
              #76968
                That would reflect the behaviour of Windows in colour managed applications where sRGB is specified. It’s possible this occurs more widely on the Linux environment you’re using, but it’s really not something I’m familiar with.
                #76969
                radosuaf
                  Great :). Now let’s just hope this stretches to 3D apps (i.e. games). Let me see…
                  #77016
                  radosuaf
                    Just a short update after doing some research. Seems like the easy way to have it working is using a KDE based distribution with Plasma 6. You can even use EDID if you don’t have the ICC profile and it does a decent job, at least in case of my AOC monitor.
