Best color calibrator?
Viewing 12 posts - 1 through 12 (of 12 total)
  • #71729
    agile.wing5673
      I love this site and I wish you had a link for the LG 27MD5KL-B because it seems to be the only monitor that meets my needs, unless anyone here can suggest an alternative? I’m looking for >=200 ppi, >=27″, DCI-P3, 16:9 (I will use 2 of them)
      That is pretty much all I have to say. Thank you!
      #71731
        Hi agile.wing5673,
        I’m glad you enjoy the content. The X-Rite i1Display Pro (now branded as Calibrite ColorChecker Display Pro) and the i1Display Pro Plus (now branded Calibrite ColorChecker Display Pro Plus) which can record higher peak brightness of up to 2000 nits are good colorimeters which give a reliable calibration. The bundled software isn’t all that ‘interesting’ to me as a reviewer and arguably isn’t the most flexible really as it doesn’t give very neat reporting. But you can use the device with other software as well if that sort of thing is interesting to you. The newer Datacolor devices such as the SpyderX series (SpyderX Elite etc.) and new Spyder X2 models (Spyder X2 Elite and Spyder X2 Ultra) are also good devices and give solid calibration results. The X2 Ultra is able to reliably record higher brightness levels up to 2000 nits. I like the reporting and intuitive nature of the bundled Datacolor software, which is why I like to use their reports and graphics in reviews. It doesn’t seem to impact the calibrations themselves in a clear way, but the devices (at least the SpyderX, haven’t tested X2 yet) aren’t good at accurately measuring very low black depths so aren’t ideal for contrast readings. Which is why we use an X-Rite sensor for that instead.
        I’m actually contemplating upgrading the SpyderX Elite to Spyder X2 Elite (don’t personally need the Ultra as the high brightness measurements are handled by our X-Rite sensor anyway). It’s interesting to me as a reviewer and I like that they’ve added Rec. 2020 into the gamuts you can compare to in their software as well. But it comes at quite a premium over the original SpyderX series or Calibrite / X-Rite packages and I can’t really say that as a normal user you should pay that premium. I’m sure it will come down in price in time, it’s very new at the moment. 🙂
        P.S. Be aware that if you want to support the website, you can visit Amazon via links to other products and then browse to the screen from there – we still get commission for purchases that aren’t the original monitor your clicked. There aren’t many ‘5K’ models or monitors with the sort of pixel density you’re after on the market, so I think you’ve chosen a good one with that LG with that requirement in mind.
        #73231
          Calibrite now has a new range of colorimeters , including the ‘top of the line’ offering which is the Display Plus HL. This one’s quite future proof in terms of luminance measurements as it goes all the way up to 10,000 nits. The Display Pro HL offers everything that this one does but is limited to 3000 nits (still useful) and doesn’t appear to support the BT.1886 tone curve for Rec. 2020 calibration. The software package (‘Calibrite Profiler’) doesn’t seem to have gained any new useful reporting features that would appeal to me as a reviewer or those who simply appreciate such things. In typical X-Rite style it’s more focused on a streamlined calibration process than useful or ‘attractive’ reporting functionality. I’m sure these devices will work well and continue on from earlier X-Rite and Calibrite branded products as reliable and accurate colorimeters.
          #73674
          Dato
            What mode do you choose in datacolor software to calibrate QD-led monitors, what works best in your practice?
            There is no dedicated mode for this(
            #73676
              ‘Wide LED’ is the best match.
              #73677
              Dato
                I want to buy new Calibrite Display SL meter, will it work with DisplayCal and can I choose different profiles for monitor like QD, miniLED and others?
                Just acquired Datacolor Spyder X Elite and was dissapointed that it not have calibrations for QD monitors and also users cant create there own, we only have built-in ones(
                Would you recommend on a budget?
                #73679
                  As far as I’m aware the Calibrite Display SL should work fine with DisplayCAL and you should be able to load in different spectral profiles to better match the monitor’s light source. But it’s not something I have personal experience with and is something you should probably enquire about on the DisplayCAL hub (forums) as you might be able to get absolute confirmation there.
                  Edit: I see you’re already active there, so that’s a good start! 😉
                  #73979
                  jbennett360
                    Not sure what’s happening with displaycal as the original creator seems to have effectively abandoned it.
                    I tried for experimental purposes this morning, using the Calibrite Profiler program with my old but reliable Colormunki!
                    I had to pay £8.99 to ‘upgrade’ and allow me to use it with the software.
                    Initial results when I compare it to Displaycal is that Displaycal probably does profile better, but not drastically. I’m talking delta 1.5/6483k with the profiler and 0.95/6504k with Displaycal.
                    Displaycal is obviously a lot more technical and has the ability to include color corrections, show more technical data at the end etc. But for what’s it’s worth I wouldn’t say the profiler software was poor. Simpler. But gets the job done
                    #73987
                      I completely agree that for most people the bundled software (or software created by the colorimeter manufacturers) is all that’s needed. I see DisplayCAL in the same way I see certain mods or modding communities for games. An additional or alternative experience driven and ultimately taken over by a passionate community, but not necessary for most people’s use of the product.
                      #76769
                      szerwony
                        Hi. I found good deal and I can buy latest Datacolor Spyder Pro 2024 for about 105 EUR. There is also Calibrite Display Pro HL available for about 169 EUR. I don’t know if I should take Spyder Pro or pay more for Calibrite. I’m not high level professional, I’m just let’s say semi-pro. I have an Eizo CS2731 monitor which I would like to calibrate from time to time with ColorNavigator and also I would like to calibrate my second gaming monitor and my girlfriend’s monitor. As I’m content creator, I sometimes need to do simple monitor measurements for reviews – how accurate are colours out of the box, gamut coverage, delta E, etc. So far I borrowed old X-Rite colorimeter from my friend and used it with DisplayCAL. Hovewer, I can’t find any info if Spyder Pro 2024 or Display Pro HL are compatible with DisplayCAL. What’s more, I can’t find any sampe reports from Calibrite or Datacolor software in case any of these is incompatible with DisplayCAL. I’m not sure if that original software would give enough informations in reporst like DisplayCAL does.
                        So, do anyone have advice on which one I sould buy and if any of these work in DisplayCAL? I would also love to see entire monitor validation report, both from Calibrite and Datacolor software, so I will know what data it measures.
                        #76772
                          Hi szerwony,
                          I’ve merged your thread with this one as it’s a suitable place. I can confirm from my own testing that DisplayCal doesn’t appear to detect the new SpyderPro, but it should work with the Calibrite Display Pro HL. I haven’t tested the SpyderPro extensively yet (I’ve only used it so far with OLEDs, not LCDs) but from what I’ve seen so far my earlier reservations still remain with respect to it not seeming to be quite as good as the Calibrite (or X-Rite) devices at measuring low black depths. I still like the software and reporting functionality – and it works nicely for measuring colour gamut and accuracy as well as providing a good overall profile for a monitor. But given you specifically wanted to use DisplayCAL and want a single colorimeter rather than using multiple devices, the Calibrite Display Pro HL is probably the best bet.
                          #76776
                          szerwony
                            Thank you for your reply. Finally I ordered Calibrite Display Pro HL 🙂
