22″~24″ monitor with built-in speakers, two HDMI, and VGA
Viewing 2 posts - 1 through 2 (of 2 total)
  • #75742
    bobvalent
      Hi, all.
      I’m looking for an affordable monitor of around 22″~24″ with built-in speakers, two HDMI and one VGA input. I’d like it to be easy to change the input source.
      I bought a scepter on Amazon, and it stop working after two days, so I’m returning it. But even if it worked, I didn’t like the fact that I had to navigate too many menus just to change the input source. I’d prefer one button per input, or one button to cycle the inputs.
      Is there anything on Amazon that fits these requirements? Thanks!
      #75750
        Given that VGA is a deprecated standard, you may find it easier to use a VGA to HDMI adaptor which will broaden your choices. You can also get HDMI to DP adaptors. There are plenty of good monitors on the market with a mixture of 3 ports (HDMI or DP). The BenQ EX240 we recommend as a ‘productivity monitor’ offers convenient input switching and decent integrated speakers, particularly for a small monitor.
